Profiler sends AB?
Discussion in 'XSimulator Q&A/FAQs - Outdated' started by pathetic, Dec 18, 2009.
  1. pathetic
    pathetic Member
    - 38Coins
    I am using tronics AMC board with his firmware.
    The profiler cant send the right datas to board so the lcd always showing 128 128 in the first two numbers.
    I have one serial port(COM1) and one usb to serial adapter(COM4)
    I made them cross cable. Then written a little terminal program to catch strings that profiler sends. (Even the same with hyperterminal connection)
    If i write AB to datapacket with axisinformation I can read AB from terminal.
    But if i use for example AB~255~ in there it sends AB? and nothing else...~ character couldnt be send
    (I tried with different baudrates also)
    With my little terminal program(COM1) I can send AB~255~~120~~110~ to hyperterminal(COM4) and read correctly. But if i use x-sim profiler it sends AB?
    I also tried to send ASCII chars for that numbers for ex --> to send AB~184~~185~~186~ i send AB©╣║
    still nothing in the lcd...
    Can anyone help me with this ?
  2. xlthamzhijie
    xlthamzhijie New Member
    i got problem outputing the force profiler outputs. I use puffy to show the output , but nothing is been displayed on the screen.
