vthinsel
Project Cars UDP Plugin - PC Version 2.1
Project Cars UDP plugin - PC version
  1. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,010Coins
    Arduino, 4DOF
    vthinsel submitted a new resource:
    Project Cars UDP Plugin - PC Version - Project Cars UDP plugin - PC version
  2. obobo
    obobo Active Member
    1,323Coins
  3. vthinsel
    FRANCE
    6,010Coins
    Arduino, 4DOF
    This one uses UDP instead of shared memory. UDP is less likely to be broken after a game patch, among other advantages
    If you are happy with the one you have, stick to it. "If it works, dont break it" :)
    If you need GameDash values provided by mine, switch to mine :)
  4. obobo
    obobo Active Member
    1,323Coins
    no need actually of game dash ... i'll stay on my actual !! but take a look on this
  5. Juan Pinto
    Juan Pinto New Member
    Homework
    Spain
    172Coins
    Good work! I want to use it with Game Dash now!
    Thanks for your work
  6. SBDESIGN
    SBDESIGN some knowledge
    director
    125Coins
    2DOF, SCN5
    im using oculus home version, when i patch it, it doesn't ask where, then states patch successful.
    I boot (this OH version) from steam.
    any ideas?
    Do you still have to make a txt file?
    cheers
  7. vthinsel
    FRANCE
    6,010Coins
    Arduino, 4DOF
    No. No more txt file needed. But you still need to activate UDP in the game settings and start the plugin
  8. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    Done this but no joy.
    Anyone got this working with Oculus Home version of Pcars?
    I haven't tried booting from oculus direct yet. I think I'll give that a go.
  9. vthinsel
    FRANCE
    6,010Coins
    Arduino, 4DOF
    You must make sure UDP data is sent to your PC once in race/pratcice. Several options to do that :
    - Use the VB_UDP_Receiver.exe file which is in the console version of the plugin (or attached to this post)
    - Use the python UDP receiver from here https://github.com/vthinsel/Python_UDP_Receiver
    - Use wireshark and check for data received on UDP port 5606
    If no traffic is received, check firewalls. In case several PCs are involved (project cars on a different PC than simtools), make sure they are on the same IP network, as project cars uses UDP broadcast which will not go through routing
  10. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    Not been on for while...
    very much appreciated, sounds right, im confident that will be the missing link!
  11. Radioproffi
    Lviv
    1,563Coins
    We are running into an issue. when two PCs are in same subnet and use UDP PCARs plugin SimTools on Both PCs are driven from PCARs game on First PC. So SimTools on both PCs are getting telemetry over UDP from one game instead of each other only from local games corresponding. Looks like UDP propagate all over LAN instead of localhost only . It is a nature of UDP?
    Looks like it is impossible to change port in PCARs and in plugin DLL.
  12. vthinsel
    FRANCE
    6,010Coins
    Arduino, 4DOF
    It is not due to UDP, but the way PCars sends data : it uses the broadcast destination IP so everyone gets the data.
    The solution is to filter based on source IP : on your PC you must block traffic from the unwanted instance of project cars. I guess windows firewall could do the job.
