Pulleys, Belts and Multi-turn Pots (Positional Feedback)
Discussion in 'Marketspace - Marktplatz' started by Roadster2, Mar 26, 2014.
  1. Roadster2
    Roadster2 Member
    1,194Coins
    I have some Aluminium pulleys, belts and pots which I'm going to make up into two packs. These parts were going to be used for positional feedback. Each pack will contain :-
    2 x T5 timing pulley - 69.2mm dia. / 12mm wide / 4mm bore / 44 teeth
    2 x T5 timing pulley - 15.05mm dia. / 12mm wide / 3mm bore / 10 teeth
    2 x T5 timing belt - 390mm x 10mm
    2 x 10k wirewound 10 turn potentiometers
    All are high quality parts and original cost of each pack is in excess of £63.
    For sale at £38 per pack including UK postage.
