Quick start simtools need help
Discussion in 'SimTools DIY Version' started by Baurus, Dec 15, 2013.
  1. Baurus
    Baurus New Member
    161Coins
    I build simulator with an arduino and simtools and i read the quickstart but i have a problems.
    I read the part : d) ARDUINO Game Engine interface settings for configure the communication into arduino and the computer. The communication is ok but when i try "moving simulator with mouse " there is no voltage on the arduino's output. I test particulary the PWM output same problems.
    In the quickstart there is no question about code for arduino. Is needed to send source code in the arduino ? for initialise communication ?
    I try to found code and extract what i need:
    void setup()
    // serial initialization
    Serial.begin(115200);
    // initialization of Arduino's pins
    pinMode(statpin, OUTPUT); //not explained by Sparkfun
    digitalWrite(statpin, LOW);
    but it's not work.
    I'm novice in programming that the big problems.
    Thanks for help and reply.
    Very Sorry for my bad english i try my best.
  2. RacingMat
    20,999Coins
    Hello!
    What is your hardware setup? Hbridge ?
    How far is your knowledge of Arduino?
    The Quick guide do let you choose anything you want : JRK, SCN, Arduino (Prilad code, RufusDufus code, mine...)
    Yours
    Mat :)
  3. eaorobbie
    20,448Coins
    Depending on Ard code you are using , follow their post where the Ard code came from not the Quick Start mate.
  4. Baurus
    Baurus New Member
    161Coins
    Thanks for reply.
    First time with arduino so for the knowledge ... ^^.
    For the arduino code i get the racingmat code but it's so big i just need the necessary for communication.
  5. eaorobbie
    20,448Coins
    Simple Serial read is easy with the Ard , I can show you a quick example if needed, I do this with my RC Model code plus the 3 dashboard codes I wrote and use.
