R´n´R v 1.3 interface in FREX system .-
Discussion in 'Rock n Ride simulators - Outdated' started by dgb13, Oct 27, 2007.
  1. dgb13
    dgb13 New Member
    Hello
    My question is this:
    The USB interface R'n'R Ver 1.3, can be applied in a chair FREX type?
    Because even in my city not in a USB interface experimental K8055-VM110 Velleman. (Mendoza -
    Argentina)
    Greetings.
    Hola
    Mi pregunta es la siguiente:
    La interfaz R´n´R Version 1.3 USB, puede aplicarse en una silla tipo FREX ?
    Dado que aun en mi ciudad no consigo una interfaz experimental USB Velleman K8055-VM110. (Mendoza -
    Argentina)
    Saludos.
  2. dgb13
    dgb13 New Member
    Hello, Thank you for your reply.
    I recommend using pots that show in the image or the link?
    http://www.fk-industrie.de/de/produktka ... K/130.html
    Hola, Gracias por la respuesta.
    Me recomiendas utilizar los pots que muestro en la imagen adjunta o el link?
  3. dgb13
    dgb13 New Member
    Thanks for your reply. Usare potenciometros linear sliding.
    Arming a system of stool (nuematico) Frex with the interface R.n.R 1.3, creates a big question, suppose:
    I have two actuators nuematicos, an A and B
    If brake in a straight line (in a simulation), the chair r.n.r, only atuador A expands; But in a system chair FREX, actuators both A and B should expand.
    In the section Hardware website (X-Sim R'n'R USB Interface), the chart describing an actuator mode PICH and another mode ROLL, to work on a chair R.n.R.
    But, apparently, the system FREX works with two valves open so PICH and colleagues in this forum only use interface K8055 for systems FREX; Taking into account all this, it is possible that even a chair FREX function an interface r.n.r 1.3 :?:
    Thank you for your time, greetings.
  4. egoexpress
    Just a question of software configuration...
    regards
  5. dgb13
    dgb13 New Member
    Thank you for both answers. In a few days I hope to finish arming interface rnr 1.3, conducted tests with the software and sends images.
    Greetings
