Question R3E problem with steering wheel and EMC utility
Discussion in 'DIY peripherals' started by Totouan, Aug 27, 2024.
  1. Totouan
    Totouan New Member
    60Coins
    Hello I just got the pro version of EMC utility with a STM32F401CCU6 board, on the EMC app, everything seems to work perfectly, the steering wheel following exactly what I do.( just brake, acc. and streering for now ). I was playing on Raceroom Racing Experience with leonardo and EMC lite before and it worked fine and now the brake and the accelerator are still working fine but the steering wheel acts like a switch, left and right at 100% imediatly when I turn the steering wheel. I checked all the others in game parametres and everything is good, that isn't the problem, looks like it doesn't recognise it as it shall. When I turn the wheel of only 1° or 90° or any degree on both side it just turn left or right at the maximum.
    I don't know what I can do, if someone could help me !
    Sorry for my english and I hope you will understand what I tried to explain.
    Totouan
  2. Totouan
    Totouan New Member
    60Coins
    I find a way to solve that by using the game controleur configurator on windows by recalibrating it but it is now complecated to change and calibrate. If someone has an idea it would still help me a lot !
    thanks
  3. Totouan
    Totouan New Member
    60Coins
    Does EMC utlity pro work with Raceroom racing experience ?
    Because now I added a H shifter but it looks like it doesn't recognise it, even it I am able to select every button in the control setting of the game...
