RACE07
Discussion in 'Force-Sender & Plugins' started by egoexpress, Mar 27, 2008.
  1. egoexpress
    RACE 07 Force-Sender plugin works fine. I am getting the same values like in GTR2 ;D
    I'll post a vid and a profile soon...
    Regards
    Christian
  2. RaceRay
    23,862Coins
    Great to hear. It is possibly record-breaking how fast you try out all the possible combinations of profiles and games :) :clap:
    I am still hoping you make the next videos from a side or perspective view of your simforceGT. *please*
    kindest regards
    René
  3. Ferrari_Man
    Ferrari_Man Member Gold Contributor
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Hey..
    How did you setup the plugin for Race 07?
    I can't get it working
    Ferrari_man
  4. egoexpress
    Afair I've used the same config like for GTR2. Though I havent tried out lap-times, gear or other info offsets. Just long/lat/alt accellerarions.
    Do you get input into the Profiler anyway?
    Regards
    Christian
  5. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Hey
    No I don't get anything in the profiler. You havn't changed anything, like write shared memory= 1? like you have to in GTR2
    To be sure.. are you using the plugin gtr2 in force-sender or Race 07... or are they the same?
    Ferrari_man
  6. egoexpress
    Weird...
    No, though I had to enable mmfs in GTR2, it worked in RACE07 without any modification.
    Afair GTR2, GTL,RACE,RACE07 do use the same memory mapped files, for that reason the Force-Sender plugin should work as like for all the titles mentioned above.
    Perhaps a vista issue once again :(
    I've used the RACE07 plugin for RACE07.
    Regards
    Christian
  7. mboRacing
    mboRacing Member Gold Contributor
    Automatiker
    Switzerland -Eiken
    - 151Coins
    Hello Ferrari_Man
    You've been fixed your problem?
    In the profiler i have no data at all. The shared memory function is enabled, i tested this with the simview toll, it has all the data's...
    Greetings
    Martin
  8. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    437Coins
    Effects 25-28 are not visible in the profiler 2.0 when using the Race 07 Plugin. They are usable in math functions though and the math function shows the output. Can anyone else confirm this? Is there anything that I could have done to cause this?
