raspberry "simtool-box"
Discussion in 'SimTools DIY Version' started by jugnor, Feb 26, 2016.
  1. jugnor
    jugnor Jugnor Gold Contributor
    Mechanical designer
    Nantes - FRANCE
    259Coins
    2DOF, SCN5
    I everyone.
    Is it possible to instal a raspeberry with a Simtool OS and make it work with network?
    If is it possible, we can make a almost plug and play motion plateforme, no?
  2. BlazinH
    16,613Coins
    No it’s not. Furthermore, why would someone want to unless they plan on running all their games on the Pi too? That doesn't make any sense.
  3. ferslash
    ferslash Active Member
    4,798Coins
    i am not sure about, but as far as i know simtools is developed in .net ide, so... i think that at least at this momento porting it to linux (rasberry) sound kind of dificult... but again, i am not in the development team (or other team) :D
    well, in the fan team :D
    fer
  4. BlazinH
    16,613Coins
    If you mean can you send data from simtools to a raspberry over a network then you should be able to if the raspberry will work with UDP.
  5. jugnor
    Mechanical designer
    Nantes - FRANCE
    259Coins
    2DOF, SCN5
    That exactly what I mean @BlazinH .
    I will wait the new version of simtool before ask develloper. They ve got enough works right now...
  6. BlazinH
    16,613Coins
    Do as you wish but it won’t do any good to wait and ask the developer because he will just tell you what I already did! Simtools allows UDP output on a network. Its up to you to get it communicating with your raspberry pi (or not). Just use NET output in Simtools and put in the address and port to your raspberry.
    http://www.xsimulator.net/simtools-game-engine/
  7. jugnor
    Mechanical designer
    Nantes - FRANCE
    259Coins
    2DOF, SCN5
    Ok thanks, I ll give some try.
    See you
