rFactor 1 Internal Plugin for Display
Discussion in 'DIY Motion Simulator Projects' started by NewRider, Apr 15, 2014.
  1. NewRider
    NewRider New Member
    305Coins
    DC motor
    Hi Guys,
    I could find this forum useful for gaming and having fun, I have a small project for rFactor 1 to do.
    I want to make numerical display for the RPM , SPEED and GEAR by PIC Micro Controller.
    and I want this data from the game, I wonder if I can send the data from the internal plugin project by UDP to receive them by C# since I am not very experienced in C++, any one have done such thing?
    Thank you in advance
  2. eaorobbie
    20,440Coins
    No need we have a GameDash application.
    That does all that for you.
    I have an example using an Ard UNO and TM1638.
    Plus there is at this time 15 games supporting it.
    And yes it is compatible with the pic.
    Once we can see your code for the pic we can advise you on how to set this up.
    I prefer to use the Ard as PIC doesn't use decimals or -ve numbers, a bit of a pain. But can be worked around.
  3. NewRider
    NewRider New Member
    305Coins
    DC motor
    Thank you eaorobbie,
    I still did not write my PIC code waiting to get the info from the game first.
    I am still do not understand what is happening here I think and need to read a lot in this forum to take benefits of your reply
    Thank you again
  4. eaorobbie
    20,440Coins
    LOL we are a group of friendly diy that build sims as a hobby, and love helping others to do the same.
    Ok lookup GameDash in the resources, I can give a value ranges for the 20 values the game dash uses with Rfactor if needed, but basically with the game dash a user can simply write very simple scripts to change the data to what they require and send it either by udp or serial(usb) to their dash of choice.
