rFactor 2 Renault Megane 150mm SLIDERS
Discussion in 'X-Sim² profiles' started by bleco, Jan 11, 2012.
  1. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    Sim: rFactor 2
    Car: Renault Megane Trophy
    Actuator type: Scn5 150mm
    X-Sim version: 2.0.8.9b
    25% limiter: NO
    75 percent scaler
    Speed and accel set in Synaptrix
    Included adjustable effects with sliders:
    - RPM, Lateral high speed, Lateral low speed, Roll, Drift, Longitural accel, Longitural brake, Pitch up, Pitch down, Gear shake, Bumps.
    V1.7 (09-02-2012)
    rFactor2 Renault Megane Bleco SLIDERS V1.7.rn2
    I also use rFactor 2 RealHeadMotion Plugin by Sébastien Tixier and have 'head movement' value to 58-60% in controls settings. https://sites.google.com/site/mididrumc ... ion-plugin
    Any positive of negative comments are welcome ... Any Thx as well ;-)
    It never felt that good!
    Enjoy!
    Bleco
  2. bleco
    Montréal, Canada
    258Coins
    Re: rFactor 2 Renault Megane profile with SLIDERS
    Corrected file for download, initially posted file did not contained sliders.
    Just reload the profile if all G-Force effects in Math are not highlighted in yellow on both axis (known issue with X-Sim).
    Bleco
  3. minikase
    minikase Member
    359Coins
    THX bleco! Nice basic profile for rfactor2.
  4. bleco
    Montréal, Canada
    258Coins
    Thx!
    Added file:
    V1.5 (22-01-2012)
    - Updated drift and lateral
    - Added speed to RPM (very smooth and progressive feeling)
    - Added cornering roll slider
    Try this one!
    Enjoy,
    Bleco
  5. Silly(c)One
    Silly(c)One New Member
    ex-Web & Industrial Dev/Sysadmin
    Brussels, Belgium
    327Coins
    Hello friend,
    I tried your profile, but couldn't make it work... rF2 is setup and recognized automatically by Force-Sender, Profiler triggers on race start, but no movement of the SCN5s at all... I probably overlooked something... Any idea ?
  6. bleco
    Montréal, Canada
    258Coins
    Hi dude!
    I just uploaded my lattest version 1.7 ... :)
    When you load the profile in the profiler can you see all effects highlited in yellow on both axis ? If not, reload the profile, make sure all effects are highlited in yellow and save it ... It's a know issue with x-sim and sliders profiles ... Or else, make sure to copy sirnoname new rF2 plugin into C:\Program Files (x86)\rFactor2\Plugins folder.
    rfactor-2-beta-now-available-for-download-t3512-10.html#p36092
    Also make sure to use the lattest rFactor plugin in your x-sim C:\Program Files (x86)\X-Sim\Plugin folder
    rfactor-plugin-t1253-20.html#p29974
    It takes 10 to 20sec before any plugin take effect in rF2, if you don't see the little data acquisition icon on the top left of the screen when starting a race then it's not seing the plugin ... once it disapears, motion should engage.
    Bleco
  7. Silly(c)One
    Brussels, Belgium
    327Coins
    It works !!!
    Beautifully I might add ! Thanks a lot for the sound advice, as usual :bow:
    I only did a quick test, and FFB on my GT2 didn't work, but I was very impressed at the motion your profile allows on rF2... As far as driving sensation goes, rF2 is THE sim of 2012 for me at this point.
    Edit: tested again, this time FFB took on... WOOOOW. This is the best feeling I ever had with X-Sim in any sim ever !
    Can't wait to drive in the Nordschleif with WSGT2 ;D
  8. bleco
    Montréal, Canada
    258Coins
    Hi mate,
    I am glad you liked it, rF2 is amazing ... I can't wait for the good mods to become available.
    Bleco
