rFactor error at launch
Discussion in 'Force-Sender & Plugins' started by Etienne, Jul 26, 2008.
  1. Etienne
    Etienne New Member
    Hello !
    I'm Etienne, I read your forum since a few years, and now have bought a VM110 card.
    After some tests, the VM110 is ok, with the test plugin.
    However, when rFactor is launched via ForceSender, an error message from rFactor appear:
    could not load *.mas...gmotor2 error
    I tried on 2 computers, one with my current rFactor, and the other with a fresh install.
    Same result on both.
    rfactor version is 1.255
    Is the plugin supporting this version?
    Etienne
  2. egoexpress
    Hi Etienne,
    try to start R-Factor as usual with r-factor.exe
    The play game button is buggy.
    Regards
    Christian
  3. Etienne
    Etienne New Member
    Ah, ok!
    I thought it was absolutely necessary to start the game with the Force sender interface.
    I will try that tomorrow.
    Etienne
  4. Etienne
    Etienne New Member
    After some tests, all work fine ! :thbup:
    It only remains now to build the simulator :)
    Thanks again, I'll post progress (nothing for the moment)
    Etienne
