Rock n Ride Instalation
Discussion in 'Rock n Ride simulators - Outdated' started by Runxax, Nov 3, 2007.
  1. Runxax
    Runxax New Member
    Hello again,
    I recive my RnR right now!!!!
    But I dont have any manual???
    Can you help me??
    Is possible use the Xsim software with serial port?
    Regards
  2. egoexpress
    What interface do you have? If you dont know, then take a photo...
  3. Runxax
    Runxax New Member
    The original old Rock’n’Ride interface, to control via serial rs232 interface.
    Regards
  4. egoexpress
    The original interface is not X-Sim compatible. You need an X-Sim interface.
    Do you have some basic soldering skills?
  5. Runxax
    Runxax New Member
    Ok I have one friend to do that.
    But I connect the RnR as you show on general specification using serial and I can move the chair by joystick. The problem is I cant move the chair acording the plane position (MSFS9).
    One more question, I have 2 compressor with 3 bar each, so I have 6 bar, is possible more Bars than 6? I have a bigger compressor with 14 Bars, can I use it?
  6. egoexpress
    If one would be able to control the RnR accordingly to plane or car position with the original interface, then we would not need the X-Sim software^^
    Think about it...
    With the orig interface just joystick mode is supported.
    For more features you need the X-Sim RnR Interface.
    Sure you can use a bigger compressor. But if I was you, I'd put a choke in between the compressor and the valves. Just in case you dont want to upgrade your RnR to a catapult ;D
  7. Runxax
    Runxax New Member
    :D :D :D :D
    But my first impression of RnR was bad..... if I move the chair to Left and right with fast moves on joystick, appear that need more pressure.
    Now Im going start all the improves to get the better result possible.
    I have one RnR chair with original interface, two compresor with 3 bar each and a possibility to use another compressor more strong (until 14 bar)
    Please tell me what I have to do :oops:
    step by step
    and all the advices that you (all of you :) ) think important
    King regards
  8. Runxax
    Runxax New Member
    Help me Please!!!
    Im a little confused?!?
    Regards
  9. SimHawk
    SimHawk Member
    Engineer
    Norway
    3 bar + 3 bar is not 6 bar, still just 3 bar with more air supply. Like one 3 bar compressor with double sized tank.
  10. Runxax
    Runxax New Member
    Seems that nobody is willing to guide me in the process of upgrading the RnR?
    Yet still waiting for that precious help ....
    I addition to being very inexperienced in these things, interfaces, motion, etc.
    I am a little confused when I read the site and the forum x-sim because I do not undestand German?
    But one thing is certain, I want very much enter in this world of Motion ....
    Help me please.
    About the answer of Bars, tank you!
  11. egoexpress
    To use the X-Sim software you need a x-sim interface!
    Ok, step by step:
    1. take a screw-driver and dismount the original interface out of the RnR
    2. put a x-sim interface in the RnR
    3. start the x-sim software
    Thats all...
  12. Runxax
    Runxax New Member
    Thank you!!
    Im going start right now.
    Regards
  13. Bryna
    Bryna New Member
    Can you please upload a couple of photos so I can see what this X-Sim interface is?
    IS X-Sim interface soemthing we buy from X-Sim?
    Thank you.
  14. yobuddy
    49,209Coins
    Bryna,
    This is what they are talking about:
    http://www.x-simulator.de/en/hardware/r ... rface.html
    There are a few different versions of it in the forums, The one pictured is a 1 to 1 replacement with the original RNR board. They are all DIY at the moment.
    Egoexpress has a version he put together that has no surface mount parts that should be easier to build if you are going to build one.
    Please take a look under the “X-Sim compatible controller interfaces” Part of this website for more options.
  15. egoexpress
    No, it hasnt been finished, and I wont spend more time on pulsmode pneumatics. Discontinued...
