Scn 6 actuator / ProSimu T1000
Discussion in 'Commercial Simulators and Peripherie' started by alioLemon, Nov 19, 2017.
  1. alioLemon
    alioLemon New Member
    - 152Coins
    SCN6
    Hallo,
    i brought last month the ProSimu T1000 rig with SCN 6 Actuator´s and it works allright.
    My question is because i run at 100% at Simtools game Manager strengh Setting it feels and sounds sometimes that the actuator "falls" the way down loses contact with the ground. Is this "Impact" bad for the actuators ? Or is this normal ?
    PS: Under the actuators there is some carpet.
    Thanks for your help
  2. prosimu
    prosimu Member Gold Contributor
    - 870Coins
    Hi Alio, As recommanded inside the doc, please set 60-80% for main level. If you put 100%, it's surealistic..... and can't be simulation. At 100%, it' normal to loses contact from the ground. Actuators have several protection, you can run like this,but not recommanded for lifetime.
    Patrick
