SCN5 device ID
Discussion in 'SimTools DIY Version' started by Balles, Jan 1, 2014.
  1. Balles
    Balles New Member Gold Contributor
    - 14Coins
    Hi all, and Happy new year !
    I can't have the software to work with my scn5s (connected on 1 usb ftdi/rs232, drivers 2.08.30).
    They work great with x-sim. In settings, the device IDs are #0 and #1.
    Someone said that I must have both IDs to #0, but I can't. X-sim says that the ID #0 is in use and I can't change the ID #1 to #0.
    I also tried to install TBVST pctool for scn5, someone said that it can do the job, but it fails to install (something with the registry fails).
    I'm stuck right now.
    Any ideas ? Thanks.
  2. RaceRay
    23,862Coins
    Only connect the actuator you want to change with XSIM and than try again to change the ID. Does it work?
