SDK
Discussion in 'XSimulator Q&A/FAQs - Outdated' started by hdsa, Jan 13, 2009.
  1. hdsa
    hdsa New Member
    I'm an Electronics Engineer from Portugal. I've been working for the last 10 years developing in the PIC Microcontroller Area. I have developed data aquisition, I/O and communication boards. I'm a newbie in the motion simulator area but I've recently start a new project in this area. The major problem for me is the short knowledge I have in the most important issue: converting the x,y,z and G-Force information from the game memory to motion movement commands. Is there any tutorial or information about these concepts??? Where can I get the SDK? Is it well documented??
    Thx in advanced,
    ps: I'm available to colaborate in the forum.
  2. tronicgr
    tronicgr
    Hi hdsa,
    With your knowledge, your help would be great!
    X-sim software can convert the game memory values to usefull data (like serial output) for you!
    For motion control you can see some information on these links:
    1) tronic-s-proportional-servo-motor-control-with-basic-stamp-t495.html (with source code to take a look into as example)
    2) implementing-pid-control-in-microcontroller-t1011.html
    Or this, that is based on AVR microcontroller but its closed source for now...
    3) tronic-s-amc-motor-motion-controller-with-pwm-servo-output-t559.html
    But there are other areas that needs support also like real moving gauges, or 7seg digital tachos, or even GLCD output support! Below is what I try to do about the servo instruments:
    4) diy-analog-servo-car-instruments-t890.html
    Best Regards, Thanos
