Seatbelt tensioner with FlyPT
Discussion in 'DIY Motion Simulator Projects' started by disko, Mar 19, 2023.
  1. disko
    disko New Member Gold Contributor
    - 339Coins
    Hi. I try to use this code for belt tensioner. In simtools works everything is fine, but in flyptmover don't. I use flypt for motion simulator, i don't want to use two software. Can somebody help me, @pmvcda perhaps?
  2. GWiz
    GWiz Active Member
    Dentist
    Aberdeenshire, Scotland
    1,504Coins
    Hi disko, 2 possibilities come to mind. I had one Arduino sketch that didn't work properly in Mover when it did in Simtools. I found that if I lowered the Serial speed to 9600, Mover was happier. You would need to change the serial speed in both the Arduino sketch and FlyPT Mover to test if this is the case for you.
    Alternatively, FlyPT Mover seems to work a little differently than Simtools with how it expects numbers to be formatted. I had a wind sketch that only sent 3 digits when it was over 100. i.e. it sent 24 rather than 024. This meant that FlyPT Mover only responded at 100 and over. (See this post: https://www.xsimulator.net/communit...-wind-arduino-sketch.14425/page-2#post-225256)
    Maybe one of these will help you, it should be possible to get your sketch working in Mover with the right settings.
