second Profiler registry setting
Discussion in 'Force-Profiler Simulator Control' started by bigtalltim, Jan 4, 2011.
  1. bigtalltim
    bigtalltim New Member
    Belfast
    361Coins
    Hi Ego
    How can this be achieved - what is the registry key that must be changed?
    Tim
  2. egoexpress
    I was referring to X-Sim1 Profiler.
    Specify your issue. I think you may not need to do this in X-Sim2.
    However, SirNoName is the one who will know it for sure.
    regards
  3. egoexpress
    I guess he wants to connect a second Velleman K8055. Thats why I asked him to specify.
  4. bigtalltim
    Belfast
    361Coins
    Hi guys - thank you for looking at this for me!
    To be more specific:
    I need to connect 2 k8055s to my PC, and use them both to drive a 3dof platform.
    One of them will have both PWM1 and PWN2 outputs in use, the other one uses only the PWM1 output.
    When I connect 2 x K8055 to my pc, my profiler appears to see only one of them in the interface area...
    If I am able to connect up to 4 vellemans to profiler 2, how can I get the interface section to recognise the different boards so that I can set up the outputs? (both of the boards need to have an analogue output 1 and a digital output channel 1 in use)
    Must I rename one of them in some way?
    Tim
  5. bigtalltim
    Belfast
    361Coins
    That is awesome - Thank you so much!
    Done in seconds, and working perfectly now - I LOVE THIS FORUM!!! :clap:
    :cheers: :cheers: :cheers:
    Tim
