Servo connections
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by early_m, May 5, 2017.
  1. early_m
    early_m Active Member
    Chelmsford
    826Coins
    I have made a G seat using servos (https://www.xsimulator.net/community/threads/diy-g-seat.9848/)
    I want to be able to disconnect the servo wires from the control box more easily and tidy things up. Currently I have 5 sets of wires going to the seat to control 5 sets of servos, using the standard servo connectors.
    Is there another suitable connector that I could use? One that would panel/flush mount on the control box would be preferable. Each set of servos is probably drawing about 3-4 amps peak.
    Thanks.
  2. RandomCoder
    Control Engineer
    1,674Coins
    Amphenol specialise in this type of connector. There not cheap, but are very good quality!
    They're readily available from retailers such as RS, Mouser, Farnell and Digikey etc.
