Request (Feature) Setup motor limit
Discussion in 'SimTools DIY Version' started by DarkHunter82, Dec 5, 2019.
  1. DarkHunter82
    DarkHunter82 New Member
    96Coins
    Good evening I built a 2dof simulator... All working... But I would need to know how to set the limits of the engines on simtools to prevent them from banging on mechanical stops... Which then makes them overheat. Thank you in advance for the answers
    147,878Coins
    +10,880 / 54 / -2
    What hardware and code are you using to control the motors, as adjusting the range and PID there would be preferable, though you can do axis limiting in SimTools?
  3. DarkHunter82
    96Coins
    I'm using arduino uno with monster motor shield and 2 motor.... I have realized the mechanical stop for min and max but I need to setup it in simtools if is possible... Thank for the reply
    147,878Coins
    +10,880 / 54 / -2
  5. DarkHunter82
    96Coins
    Thanks for reply... I have readed the manual but I don't understand if I can setup max and min value separately
