Question Several questions about when using DOF reality.
Discussion in 'New users start here - FAQ' started by LemonIcetea, Jul 27, 2021.
  1. LemonIcetea
    LemonIcetea New Member
    123Coins
    3DOF, 6DOF
    Hello!
    I have several questions.
    For the first time, I'm sorry if my English is not smooth.
    It's because I used a translator.
    Previously, I have been using SRS in my project, but there is a problem, so I want to change it.
    1. In the patch note in Simtools, it was written that offline mode is possible after license authentication, but is it right that it does not require repeated authentication in an offline environment?
    2. Can the SMC3 command set issue commands directly from Unity to the (DOF reality) motion box without using sim tools?
    2-1. If yes, is there an example?
    3. When I checked, I think Sim tools has a setting to send it to the DOF reality setting. Where can I check it?
    (I haven't purchased a sim tools license yet, but only conducted a basic test using a trial version. I'm so sorry if there's a formal version.)
    I add that I might need more information.
    It is used by Unity and using SRS api (+ Telemetry).
    152,718Coins
    +11,092 / 56 / -2
    1. Once authenticated does not require repeated authentication in an offline environment.
    2. SMC3 controls the hardware but needs some way to get game data directed instructions, which is what SimTools does. I don't know about the (DOF reality) motion box. I presume you mean the Unity game engine, if you are building something in Unity and want to use it with SimTools and motion then see here: https://www.xsimulator.net/communit...ry-output-into-a-game-unity-and-ue4-code.287/
    3. The demo version of SimTools comes with the fully functional Live For Speed plugin, specifically for testing purposes: https://www.lfs.net/downloads
    There is a dedicated DofReality thread: https://www.xsimulator.net/communit...-3dof-6dof-motion-simulator-dof-reality.8570/
    Sorry I don't know anything about the SRS api.
  3. LemonIcetea
    123Coins
    3DOF, 6DOF
    Thank you for your reply.
    In the case of SRS, they asked for re-certification if the program was turned on again even after authentication.
    I will check additionally and purchase sim Tools license to proceed with the project.
    Thank you once again.
