Sim tool 1.2 X-plane 10
Discussion in 'X-Plane' started by Abdul Hameed, Mar 15, 2014.
  1. Abdul Hameed
    Abdul Hameed New Member
    437Coins
    2DOF, 3DOF, DC motor, AC motor, SCN5, SCN6, SimAxe, Arduino, JRK, Joyrider, SimforceGT, Motion platform, 4DOF
    i testing Sim Tool 1.2 X plane-10 plugin not working, When i start the game motors moving to center position then no response dead.
    LFS,Roller coaster i can test virtual Axis mode from Sim Tool output works as expected,
    when i test X- Plane 10 with virtual Axis mode from Sim Tool no response no output
    do i miss anything from the X-plane settings?
  2. value1
    14,753Coins
    Hi @Abdul Hameed
    I'm reinstalling X-Plane after I annihilated my SSD. And it takes ∞ time.
    In the meantime you probably want to have a look at this post, where I explain, how to install the plugin manually.
    (Yes, it's about X-Plane 9 but works alike for X-Plane 10)
  3. Historiker
    Michigan USA
    9,195Coins
    I had to snicker when I read that ;)
    • Funny Funny x 2
  4. Abdul Hameed
    437Coins
    Thanks for reply,
    Yes I followed the post and manually installed plugin, now I can see the axis values.
    The issue was localhost 127.0.0.1
    But my motors are not working as expected. Motors moves only at start then nothing .....
    I have 2motors
    Surge 60% surge 60% default setting
    This point do I need to change other options from sim tool axis presetting default to motion x etc....
  5. Abdul Hameed
    437Coins
    I mean surge and sway
  6. cpvasconcelos
    cpvasconcelos New Member
    208Coins
    SCN5
    Hello all.
    I am a new forum member, currently own a SIMXPERIENCE STAGE IV and live in Portugal. I am looking for x-plane 64 bits plugin as simcommander only supports the 32 bit version. Can you please confirm if simtools is compatible with 64bit version?
    Thank you.
  7. value1
    14,753Coins
    hi @cpvasconcelos
    I *think* the plugin is compatible with both versions. To be 100% sure I will need to check though.
  8. value1
    14,753Coins
    LOL, the plugin was working fine in 64bit mode but not in 32bit mode.
    Now it works fine for both versions! :thumbs
    @cpvasconcelos: Thanks for asking ;)
  9. cpvasconcelos
    208Coins
    SCN5
    Thank you very much.
    Being a newybie here, the fastest way to try it out is to purchase 29 eur credits, right?
    Ps - is there any risk of using simtools in simxperience? (Meaning burning actuators or simx3000 board?)
  10. cpvasconcelos
    208Coins
    SCN5
    Worth checking out :
    and this:
    Very good stuff from xplane with real satellite images (realscenery.com and simheaven.com) along with some plugins and ipad apps.
  11. Slider
    Slider Active Member
    Irrigation
    Brisbane
    1,130Coins
    2DOF, JRK
    That looks great with the triple head setup, cant wait to get mine working.
  12. eaorobbie
    20,432Coins
    We have a big influx of simx guys converting over presently, most are removing the Simx box and rewiring the plugs to separate RS adapters which are dirt cheap (about 10 bucks) and hooking them directly to the pc via a usb connection. Once both set with a base id of '0' SimTools can be setup.
    This doesn't destroy the original box so if not satisfied (which you wont be) you can revert everything back to the way it was.
  13. cpvasconcelos
    208Coins
    SCN5
    Thanks.
    Anyway, I got it working simtools and simxperience, without any rewiring.
    Like another member posted, scn5 actuators are visible under com3, com4, com5... Then just a matter of correctly configuring the axles.
    Works like a charm.
    In this case what would be the benefit of rewiring to direct connection of actuators to pc?
    Cheers.
  14. nff
    nff New Member
    portugal
    - 93Coins
    SCN5, SCN6
    I wish someone developed further
