simtool plugin not working
Discussion in 'Assetto Corsa' started by stefanlelefan, Nov 7, 2022.
Tags:
  1. stefanlelefan
    stefanlelefan New Member
    17Coins
    SimAxe, SimforceGT, Motion platform
    Hi, I've been trying to install the assetto corsa plugin from the simtool website but it doesn't work. Is it because I am using simtool v2.5 and not v3 ? I have a DIY license but i can't switch to the v3 as I've already activated my license on the v2.5
    Does anyone have an explanation ?
  2. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    154,732Coins
    +11,194 / 57 / -2
    License and version matters are separate from the plugin issue.
    So, on SimTools v2 what happens when you install the AC plugin, does it install correctly or throw an error?
    Have you configured a motion profile for AC and if so please post pictures?
    Have you patched AC and if so were there any error messages?
    @Daguru is correct, make sure you have the latest SimTools v2 installed and you can register with v3, both can be run on the same computer.
  4. lysa elec
    lysa elec LYSA ELEC
    16Coins
    i have the same problem after the last update
  5. laffont
    laffont New Member
    - 24Coins
    Same problem does Sela come from the sit web or SIM tool?
