SimTools and Simcommander (Simvibe/GS4)
Discussion in 'SimTools DIY Version' started by BRich, May 22, 2015.
  1. BRich
    BRich New Member
    356Coins
    2DOF, SCN6, 6DOF
    I'm trying to get SimTools and Simcommander work together for iRacing and NoLimits. No luck though, either SimTool for SCN6 motion or Simcommander for GS-4 motion, but not both at the same time. Anyone got these two application working together?
    147,878Coins
    +10,879 / 54 / -2
  3. BRich
    BRich New Member
    356Coins
    2DOF, SCN6, 6DOF
    Thanks noorbeast. The link you provided help me somehow get iRacing working with Simtools and Simcommander together. I had to move the GS-4 USB connection to a different port. I'm glad that atleast I get to see and experience it myself that this two application can work together. For NoLimits Roller Coaster though, I can't get Simtool and Simcommander work together. Sigh...I wish it was as easy as plug and play on all games just like iRacing.
  4. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,261Coins
    Yes, I have both running. Some games cause more problems than others but for the most part they work well together.
  5. zigzag49
    zigzag49 Active Member
    712Coins
    Bonjour
    Je ne sais pas si fallai que j'ouvre un autre fil , car j'ai un souci similaire avec pcar's et le dashboard renovatio srd-9c .
    Les deux ne peuvent fonctionner ensemble , lorsque je met en route le jeu un message d'erreur de simtool s'affiche me disant que le plugin c'est arrêter.
    Merci
    Hello I do not know if fallai I open another thread, because I have a similar problem with PCAR's and the dashboard renovatio SRD-9c. Both can not work together,when I starts the game simtool an error message saying that the plugin is stop. Thank you
  6. darkcrayon
    darkcrayon Member
    New York, NY
    305Coins
    3DOF, SCN5, 6DOF
  7. GTHQ_koop
    GTHQ_koop Active Member
    Something with airplanes..
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    Me2, Assetto Corsa only though because that's all I got on the PC :D
