Question Simtools and Xbox one
Discussion in 'SimTools DIY Version' started by Adrian-33, Sep 11, 2018.
  1. Adrian-33
    Adrian-33 New Member
    123Coins
    hello
    I would like to know how to connect my Xbox One to my PC where simtools is installed and that it communicates with them in UDP to run the simulator.
    What are the parameters to enter in simtools and how can I test that.
  2. yobuddy
    49,199Coins
    There is no special connection to make buddy.
    you would simply connect each device to the same switch (make sure they are on the same logical network anyway).
    What is special thou is plugins that are made for consoles, like this one here.
    https://www.xsimulator.net/community/marketplace/f1-2017-udp-plugin-manual-plugin-start.198/
    These plugin are sometimes called Manual, Console and sometimes UDP can be manually started on the PC as to make the connection.
    Be aware that there are not a lot of these kinds of plugins as there are not a lot of xbox and ps4 games that output data.
    take care,
