Question Simtools Decimal Output constant length?
Discussion in 'SimTools DIY Version' started by domse, Mar 26, 2022.
  1. domse
    domse New Member
    Lithuania
    72Coins
    i am having a problem where an off-shelf simulator does not understand commands if the value is not 3 digits long. For example:
    OC(01,255) - move motor 1 to the end
    OC(01,000)- mover motor 1 to the start
    Simtools axis output:
    OC(01,<Axis1a>)
    Everything works with values 100-255, but values under 100 get ignored, because they are 2 or 1 digits long.
    Simtools output: OC(01,99) - not understood by the simulator. Correct value should be OC(01,099).
    Any idea how to fix this?
    Thank you
  2. yobuddy
    49,887Coins
    What interface are you using buddy?
    Binary output automatically pads, as binary output is usually being sent to a micro-controller.
    But if you can't use binary output, then i can customize an interface for you.
  3. domse
    domse New Member
    Lithuania
    72Coins
    I'm using serial interface. I can't use binary because the simulator uses a proprietary controller and only accepts decimal values that are 3 digits long.
    Your help would be appreciated!
  4. yobuddy
    49,887Coins
    Please close SimTools.
    Then use the plugin installer to install this plugin.
    Then relaunch SimTools and give it another go!
    Chat soon!
