Question Simtools does not send a new signal after 1 minute of operation.
Discussion in 'SimTools DIY Version' started by Luu Vy, Jul 15, 2025.
  1. Luu Vy
    Luu Vy New Member
    12Coins
    I have a 2 dof simulator project using Simtools to send signals to Arduino but when playing or testing in output testing, the signal can only be sent for about 1 minute then simtools does not send any new signals to Arduino anymore, but when I check the LCD displaying the Pitch, Roll, etc. values, Arduino is still connected but all data freezes at the last values it received before stopping.
    151,455Coins
    +11,038 / 56 / -2
    Can you please specify what code you are using with the Arduino.
  3. Luu Vy
    Luu Vy New Member
    12Coins
    #include <Wire.h>
    #include <LiquidCrystal_I2C.h>
    #include <PID_v1.h>
    #define MP1 10 // PWM CW
    #define MP2 11 // PWM CCW
    #define ML1 6 // PWM CW
    #define ML2 9 // PWM CCW
    #define POT_R A0
    #define POT_L A1
    char buffer_data = 0;
    int buffercount = -1;
    byte commandbuffer[7] = {0};
    int pitch = 0, sway = 0, roll = 0;
    double err_L, err_R, err_sway, err_roll, err_pitch;
    double motor_R = 100;
    double motor_L = 100;
    // -------------------- LCD ------------------------------
    LiquidCrystal_I2C lcd(0x27,20,4);
    // -------------------- PID ------------------------------
    double inputR, outputR, setpointR;
    double input, output, setpoint;
    double kp = 2.8, ki = 20 , kd = 0;
    PID pidRight(&inputR, &outputR, &setpointR, kp, ki, kd, DIRECT);
    PID pidL(&input, &output, &setpoint, kp, ki, kd, DIRECT);
    void setup() {
    Serial.begin(115200);
    lcd.init();
    lcd.backlight();
    lcd.setCursor(0,0);
    pinMode(POT_R, INPUT);
    pinMode(MP1, OUTPUT);
    pinMode(MP2, OUTPUT);
    pinMode(POT_L, INPUT);
    pinMode(ML1, OUTPUT);
    pinMode(ML2, OUTPUT);
    pidL.SetMode(AUTOMATIC);
    pidL.SetSampleTime(10);
    pidL.SetOutputLimits(-255, 255);
    pidRight.SetMode(AUTOMATIC);
    pidRight.SetSampleTime(10);
    pidRight.SetOutputLimits(-255, 255);
    void loop(){
    readSimTools();
    process_signal();
    MotorLeft();
    MotorRight();
    showLCD();
    void readSimTools()
    while(Serial.available())
    if(buffercount==-1)
    buffer_data = Serial.read();
    if(buffer_data =='S')
    {// Start game
    buffercount=-1;
    else if(buffer_data =='E')
    { //End game
    buffercount=-1;
    else if(buffer_data =='P')
    { //"P" is the marquer. If we read P, the next data is pitch
    buffercount=0;
    else // if(buffercount>=0)
    commandbuffer[buffercount]=buffer_data; // The first value next to "P" is saved in commandbuffer in the place "buffercount"
    buffercount++;
    if(buffercount > 6)
    if(commandbuffer[6]=='C') // If the third data is "C", then commandbuffer is full, we can use it
    pitch=(commandbuffer[0])*256+commandbuffer[1];
    sway=(commandbuffer[2])*256+commandbuffer[3];
    roll=(commandbuffer[4])*256+commandbuffer[5];
    //ma
    sway=map(sway,0,1023,0,200);
    pitch=map(pitch,0,1023,0,200);
    roll=map(roll,0,1023,0,200);
    buffercount=-1; // Re-initialize buffercount.
    void process_signal()
    err_pitch = pitch-100; //pitch = len doc
    err_sway = sway-100; //sway = trai phai
    err_roll = roll-100; //roll = xoay vong
    //truyen dong co
    err_R= 2*err_pitch - 3*err_sway + err_roll;
    err_L= 2*err_pitch + 3*err_sway - err_roll;
    motor_R=100 + err_R;
    motor_L=100 + err_L;
    if(motor_R>160) motor_R=160;
    else if(motor_R<40) motor_R=40;
    if(motor_L>160) motor_L=160;
    else if(motor_L<40) motor_L=40;
    void MotorLeft(){
    int rawPotL = analogRead(POT_L);
    input = map(rawPotL, 0, 1023, 0, 360);
    setpoint = motor_L;
    pidL.Compute();
    if(output > 10){
    analogWrite(MP1, output);
    analogWrite(MP2, 0);
    } else if(output < -10){
    analogWrite(MP1, 0);
    analogWrite(MP2, abs(output));
    } else {
    void MotorRight(){
    int rawPotR = analogRead(POT_R);
    inputR = map(rawPotR, 0, 1023, 0, 360);
    setpointR = motor_R;
    pidRight.Compute();
    if(outputR > 10){
    analogWrite(ML1, outputR);
    analogWrite(ML2, 0);
    } else if(outputR < -10){
    analogWrite(ML1, 0);
    analogWrite(ML2, abs(outputR));
    } else {
    // =========== 3. Hiển thị LCD =========================
    void showLCD(){
    lcd.setCursor(0,0);
    lcd.print("P:"); lcd.print(pitch); lcd.print(" S:"); lcd.print(sway);
    lcd.setCursor(0,1);
    lcd.print("R:"); lcd.print(roll); lcd.print(" Pot:"); lcd.print((int)inputR);lcd.print("/");
    lcd.setCursor(0,2);
    lcd.print("SP:"); lcd.print((int)setpointR);lcd.print("/"); lcd.print(" "); lcd.print((int)outputR);lcd.print("/");
    lcd.setCursor(0,3);
    lcd.print("MR:"); lcd.print(analogRead((int)POT_R)); lcd.print(" ML:"); lcd.print(analogRead((int)POT_L));
    Serial.print(setpointR);
    Serial.print(" ");
    Serial.print(inputR);
    Serial.print(" ");
    Serial.println(outputR);
    151,455Coins
    +11,038 / 56 / -2
  5. yobuddy
    50,743Coins
    How fast are you sending the packets to the Arduino? My guess is the LCD takes a bit of time to update and when it gets behind it stops working. Please try an output rate of 50ms from the interface and see what happens.
