Bug SimTools not connecting with simulator after last Win10 update
Discussion in 'SimTools DIY Version' started by KamiFern, Jan 17, 2018.
  1. KamiFern
    KamiFern New Member
    Sherbrooke, Canada
    642Coins
    DC motor, 4DOF
    Simulator
    1. DIY:
    2. DOF (Number of axles ): 4
    3. Actuators (DIY, SCN5 etc.): industrial motors
    4. Interface (Arduino, SCN, Mega, DIY etc. ): Mega
    SimTools
    1. Version Number: 2.2
    2. Game Plugin where the error is happening: ALL
    3. Settings (Relevant settings) : Settings lost after Windows update
    One day I was playing on Project Cars, then after I launch the last update of Windows about 3 weeks ago, SimTools could not connect any more to my controler. I found that Windows changed the COM port from 4 to 5 and even after making the changes in SimTools, I still can not connect.
    I uninstalled version 2.1 erasing setup files and installed full version 2.2
    Still can not connect when trying to test. However, after the count down when I should be able to test, I can connect to the controler with another application and move all motors without telling me that the connection is not available. SimTools never tell me that the connection can not be made.
    Anyone had that kind of problem ?
    Regards
    Fern
  2. yobuddy
    49,199Coins
    My guess would be that ip6 got enabled or ip4 got disabled?
    Does seem strange, as no windows update have messed with any settings on my PC, so far anyway. lol
  3. KamiFern
    KamiFern New Member
    Sherbrooke, Canada
    642Coins
    DC motor, 4DOF
    Thanks for the cue but that did not help. I made sure only ipv4 was active and it did not solve the issue
  4. yobuddy
    49,199Coins
    Maybe a firewall of something like that?
    SimTools chatters over UDP mostly.
  5. KamiFern
    KamiFern New Member
    Sherbrooke, Canada
    642Coins
    DC motor, 4DOF
    SimTools is not communicating with the ComPort, do you think UDP has something to do with it ?
    Regards
    Fern
  6. yobuddy
    49,199Coins
    It's really hard for me to say from here buddy.
    If you expect that the com port got changed by windows (which seems strange to me as to why it would do that?) then maybe there is an error with what COM port it is actually on?
    I would try to change the com port of the device to a new port, like COM7 or something.
    Then assign it correctly in SimTools and give it a go.
    Is there anything else that changed when the windows update happened?
    New antivirus or anything like that?
    I'm on win10 also, all updated, so i could test things if there is anything else that changed?
    Take care,
  7. KamiFern
    KamiFern New Member
    Sherbrooke, Canada
    642Coins
    DC motor, 4DOF
    I agree
    I changed the device back to Com4 and it would not connect
    I do not know if anything else has changed, I use that computer mainly for racing. I spent most of the last weeks working on a LinuxCNC project.
    By the way, my old eyeballs have a real hard time reading the small characters on my screens. If I change the scale to 125%, SimTools do not display right. It would be nice to have this corrected.
    I did not change anything myself on the pc but something strange happened here today on one of my shop PC that was updated recently, it stopped executing an application and I had to change Defender preferences to have it run again.
    I am not a fan of windoze, they keep changing the way my computer works.
    If you think of something else, let me know
    Regards
    147,878Coins
    +10,880 / 54 / -2
    Sounds like your shop computer was affected by a Windows Defender change, so try switching Defender off for a moment and see if that is the culprit.
  9. yobuddy
    49,199Coins
    Fixed in SimTools v2.2
    Try to change it to a com port you have not used before, maybe COM7.
    take care,
  10. RandomCoder
    Control Engineer
    1,674Coins
    What manufacturer of motherboard do you have? Is there any news/updates on their website?
    What does Windows Event logs say?
    I'm currently having issues with my day-to-day PC thanks to the latest Microsoft vulnerability update. I have an ASUS motherboard and they seem to have been affected by the update. AI Suite and fan controls completely stopped working. My Ethernet card is also misbehaving, I can connect to the internet fine but I can also see that it's dropping out and reconnecting continuously in the logs.
    ASUS have already released a Beta fix for AI Suite and I think have started rolling it out on the support pages for each motherboard.
  11. yobuddy
    49,199Coins
    I have an asus maximus hero.
    But I'm not using any of their apps at the moment.
  12. KamiFern
    KamiFern New Member
    Sherbrooke, Canada
    642Coins
    DC motor, 4DOF
    Nice, I will do the switch
    I tried with COM20 and also disabled Defender but no change. I noted that the serial parameters are always clear when I reload Game Engine and I am not sure if the save button which seems to be a simple label that you click, does it's purpose or not
    I had a problem about 3 years ago with AVG or Avast, that decided that 'snap.dll ' was a virus and put it into quarantine rendering my CAD almost unusable until after many reinstall I had a notification about that.
    I tried to find if Defender did the same but could not find a list of deleted files.
    I wonder if I have a hardware problem but still I can access my controler with my own configuration app and move the seat normally with any COM port defined.
    I also installed X-Sim to find if it was working but extractor.exe would not load, so...???
    The mother board and CPU I7-920 (released Q4-08) are quite old but in most cases it is still faster than my newer I5 pc. I am planning to upgrade it next April with some of the latest with 24gb ram or more to improve overall performance (CAD, racing, Delphi programming, etc)
    Do not feel sad about this situation but like my CAD problem, just communicating with other people helped solve it.
    Any ways the pc will be upgraded and I will not have much time to use it for the next couple months but I always feel good when I sim race ...
    Regards
    Fern
  13. yobuddy
    49,199Coins
    I would completely remove SimTools at this point and then re-install SimTools v2.2.
    Let me know how it goes buddy,
  14. KamiFern
    KamiFern New Member
    Sherbrooke, Canada
    642Coins
    DC motor, 4DOF
    I did completely remove SimTools, disabled ALL options I found for Defender then reinstalled SimTools to no avail...
  15. RandomCoder
    Control Engineer
    1,674Coins
    First you need to determine if the problem is related to Windows or an antivirus issue. It's there anything in Windows Event log that could help to determine why the program doesn't start?
  16. yobuddy
    49,199Coins
    I have submitted SimTools to the Windows Defender guys for review.
    This should be sorted shortly.
    But for now, If you were to install AVG free and then install SimTools, i bet it would work.
    Take care,
  17. yobuddy
    49,199Coins
    SimTools v2.2 has passed the Windows Defender review.
    The next update for Windows Defender should fix the problem.
    If anyone knows of other antiviruses i should submit SimTools v2.2 too also, please let me know.
    Take care,
  18. KamiFern
    KamiFern New Member
    Sherbrooke, Canada
    642Coins
    DC motor, 4DOF
    I found this in the log about DistributedCOM, do not know if you understand anything in it but to me it is like trying to understand the physic maths of StarTrek
    Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
    - <System>
    <Provider Name="Microsoft-Windows-DistributedCOM" Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" />
    <EventID Qualifiers="0">10016</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8080000000000000</Keywords>
    <TimeCreated SystemTime="2018-01-23T13:36:30.238621800Z" />
    <EventRecordID>1561</EventRecordID>
    <Correlation />
    <Execution ProcessID="584" ThreadID="1276" />
    <Channel>System</Channel>
    <Computer>ASUS-F3D</Computer>
    <Security UserID="S-1-5-19" />
    </System>
    - <EventData>
    <Data Name="param1">propres à l’application</Data>
    <Data Name="param2">Local</Data>
    <Data Name="param3">Activation</Data>
    <Data Name="param4">{6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}</Data>
    <Data Name="param5">{4839DDB7-58C2-48F5-8283-E1D1807D0D7D}</Data>
    <Data Name="param6">AUTORITE NT</Data>
    <Data Name="param7">SERVICE LOCAL</Data>
    <Data Name="param8">S-1-5-19</Data>
    <Data Name="param9">LocalHost (avec LRPC)</Data>
    <Data Name="param10">Non disponible</Data>
    <Data Name="param11">Non disponible</Data>
    </EventData>
    </Event>
    ... and if you can read french :
    Les paramètres d’autorisation propres à l’application n’accordent pas l’autorisation Local Activation pour l’application serveur COM avec le CLSID
    et l’APPID
    au SID AUTORITE NT\SERVICE LOCAL de l’utilisateur (S-1-5-19) depuis l’adresse LocalHost (avec LRPC) s’exécutant dans le SID Non disponible du conteneur d’applications (Non disponible). Cette autorisation de sécurité peut être modifiée à l’aide de l’outil d’administration Services de composants.
    Another one about WAS
    Le service d'activation des processus Windows (WAS) s'arrête, car il a rencontré une erreur. Le champ des données contient le numéro de l'erreur.
    - <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
    - <System>
    <Provider Name="Microsoft-Windows-WAS" Guid="{524B5D04-133C-4A62-8362-64E8EDB9CE40}" EventSourceName="WAS" />
    <EventID Qualifiers="49152">5005</EventID>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2018-01-23T13:35:45.517658800Z" />
    <EventRecordID>1543</EventRecordID>
    <Correlation />
    <Execution ProcessID="0" ThreadID="0" />
    <Security />
    </System>
    - <EventData>
    <Binary>0D000780</Binary>
    </EventData>
    </Event>
    If I have a chance today, I will try to find what it is about
    Fern
  19. RandomCoder
    Control Engineer
    1,674Coins
    I'm sorry but this doesn't look like it's related to your problem with SimTools. To be sure you could try clearing the logs and then repeat the program crash and check if a new event is created.
    The event log above looks like a typical Windows Event and nothing to worry about.
