SimXperience II - NoLimits Profiles
Discussion in 'X-Sim² profiles' started by bvillersjr, Jan 25, 2009.
  1. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    437Coins
    Here is a quick profile for NoLimits v1.7.2. I specifically designed it for my favorute coaster (River Raid). I'm not sure how it will perform on other coasters.
    This profile was designed for 150mm SCN5 actuator 2DOF Sims.
    SimXperienceNoLimits.zip
  2. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Hi!
    Again, tested with your profile...
    I changed some numbers, gave more emphasis on the vert accel (it is the one that changes more).
    I miss more punch still.
    I was thinking about adding some sort of vibe back and forth on long axis, this would increase frequency with speed... But, I guess there is no way to do it, right?
    I would need to include a tooth-saw like wave with freq changing as a function of speed. :brows:
    Worth to spend time?
    Cheers,
