SMC Electric actuators - will they work
Discussion in 'Motor actuators and drivers' started by ninja, Jun 6, 2009.
  1. ninja
    ninja New Member
    Hi Team
    I am very new to motion simulation and intend building a frex type simulator. I can buy these actuators and controllers locally (http://www.smc.co.nz/product/102/Electr ... es_LZ.html) does anyone know it they will work or tried them? - or is the SCN5 a better option. I would have to import the SCN5 compared to being able to buy the SMC locally.
    I would appreciate any feedback
    Regards
    Reid
  2. RaceRay
    23,864Coins
    At first, welcome here :)
    I flick through the documentation of the actuator and with some adaptation i assume it is possible. Before research the ways of connectivity, it is more interesting how expensive the SMC actuators are.
    I don´t think that they are cheaper, because payload is much more higher as the SCN5 and speed is not so much slower.
    So, give us a nice price and we can continue talk about them. Otherwise i only suggest the SCN5 ones. They are well tested and fit perfect for our needs.
    Just a though: The modell L ZC 5H got a thrust of 72N and 200mm/sec speed (without load). That could be suitable to build a 3DOF fullmotion simulator. (not fast as the popular 301 ;) )
    regards
  3. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,690Coins
    72N =7,2kg
    You need to beam it up Scotty
  4. RaceRay
    23,864Coins
    Ups, don´t ask why i thought, i must be drunken :) Had interpreted 720N when i flick the specs..
    Use the SCN5!!!! :)
  5. ninja
    ninja New Member
    Thanks for that
    I will use the SCN5
    Regards
    Reid
