Question SMC using encoder creeps
Discussion in 'Miscellaneous' started by Eli Wizard, Jun 19, 2024.
  1. Eli Wizard
    Eli Wizard New Member
    Ottawa
    32Coins
    My rig uses encoders on the motors and I'm trying to use SMC.
    I've got an UNO, IBT-2 and a small 12v motor with reduction gearbox and an osepp encoder fitted to motor shaft set up for testing.
    I've got the encoder into the SMC code and:
    -the SMC monitor displays a near perfect overlay of target and feedback
    - the motor appears to be in sync but is advancing (or regressing).
    It did not behave like this using a pot for feedback so I don't think the gears are at fault.
    Instead of keeping a constant sweep of 2 > 5, 5 > 2, 2 > 5,,, it goes something like 2 > 5, 5 > 2, 2 > 6, 6 > 3, 3 > 7,,,
    the encoder is mapped:
    SWmulti = map(SMPulseCount, -512, 512, 0, 1023);
    How may I stop creeping?
    thanks
  2. Eli Wizard
    Ottawa
    32Coins
    and here's the sketch I'm inserting, I can't post the SMC sketch with it in it (too many characters)
    Code:
    int SMsensor01;
    int SMsensor02;
    int SWmulti;
    int SMstepOld;
    int SMstep;
    long SMPulseCount;
    #define SMSENSOR_A 2
    #define SMSENSOR_B 3
    void checkState(){
      SMsensor01 = digitalRead(SMSENSOR_A);
      SMsensor02 = digitalRead(SMSENSOR_B);
      if(SMsensor01 == 1 && SMsensor02 == 1){
        SMstep = 0;
        if(SMstepOld == 1){
          SMPulseCount--;
        if(SMstepOld == 3){
          SMPulseCount++;
        SMstepOld = 0;
      if(SMsensor01 == 0 && SMsensor02 == 1){
        SMstep = 1;
        if(SMstepOld == 2){
          SMPulseCount--;
        if(SMstepOld == 0){
          SMPulseCount++;
        SMstepOld = 1;
      if(SMsensor01 == 0 && SMsensor02 == 0){
        SMstep = 2;
        if(SMstepOld == 3){
          SMPulseCount--;
        if(SMstepOld == 1){
          SMPulseCount++;
        SMstepOld = 2;
      if(SMsensor01 == 1 && SMsensor02 == 0){
        SMstep = 3;
        if(SMstepOld == 0){
          SMPulseCount--;
        if(SMstepOld == 2){
          SMPulseCount++;
        SMstepOld = 3;
    void setup() {
      attachInterrupt(0, checkState, CHANGE);
      attachInterrupt(1, checkState, CHANGE);
      //Serial.begin(9600);
      SMPulseCount = 0;
    void loop() {
      if(SMPulseCount > -1){
      if(SMPulseCount < 10 && SMPulseCount > -10){
      if(SMPulseCount < 100 && SMPulseCount > -100){
      if(SMsensor01 == 1){
      else{
      if(SMsensor02 == 1){
      else{
      SWmulti = (SMPulseCount - 850);
      SWmulti = constrain(SWmulti, 0, 45);
        Serial.print("SMPulseCount: ");
        Serial.print(SMPulseCount);
        Serial.print("\t");
        Serial.print("SWmulti: ");
        Serial.println(SWmulti);
        //Serial.print("SMPulseCount: ");
        //Serial.println(SMPulseCount);
