Smc3 manual move
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by 90kgOver300m, Oct 14, 2023.
  1. 90kgOver300m
    90kgOver300m Member
    Maintenance technician
    United Kingdom
    263Coins
    Hi, feel like this might be an obvious answer, I have setup my motors and pots in SMC3, had to swap some polarities but the motors are now matching and driving correctly to the pots which I'm super happy about! Finally got some motion.
    A thing I've noticed on my 2Dof setup, is that although the motors are matching the pots, in the manual move where I drag the slider, if the slider is for example up, motor 1 goes up and motor 2 goes down.
    Am I correct in thinking I need to swap the polarity of one motor and pot setup, so that they both move down when the slider is down etc..
    TIA
  2. 90kgOver300m
    90kgOver300m Member
    United Kingdom
    263Coins
    On second thoughts, surely I don't want to put 5v onto the gnd leg of the hall sensor? Any knowledge will be appreciated :)
    147,656Coins
    +10,869 / 54 / -2
    You can change the wiring, the other option is that the Dir in SimTools Axis Assignments being assigned or not determines which way each motor moves for that particular axis.
