SMC3 Utils & INO file-Need to run 3rd motor @ 25kHz
Discussion in 'Miscellaneous' started by Eli Wizard, Feb 16, 2026 at 18:27.
  1. Eli Wizard
    Eli Wizard New Member
    Ottawa
    28Coins
    Hi All,
    my third motor is exclusively for heave and SMC3 UTIL 'motor3' only gives 4 or 31 kHz as options. Can I simply edit the file to 15 kHz? "Timer2FreqkHz = 15" And have all motors on 15kHz. Failing that my other option is to swap my least motor stressed to 3 as the heave axis is the one most stressed.
    Tks
