Question SMC3 works, Game Engine does not work
Discussion in 'SimTools DIY Version' started by Alexandre Haidu, Jun 18, 2018.
  1. Alexandre Haidu
    Alexandre Haidu New Member
    - 71Coins
    Hello, my settings follow, success in smc3, but not in Game Engine outout testing.
    I already disabled anti-virus and firewall.
    Heeeeeeeeeelp
  2. Historiker
    Michigan USA
    9,195Coins
    I think that the issue is in your output settings. Simtools recognizes each axis by specific letter. So it should read more like this: "[A<Axis1a>][B<Axis2a>]", also remove the startup and shutdown as they are again not using the correct nomenclature. And of course make sure you do not have SMC3 utilities running while trying to use Simtools.
    Each motor is listed by letter starting with A, so your first motor is A, the second is B, and so on.
  3. Garrick H. Woods
    Garrick H. Woods Simulator Noob
    194Coins
    I'm having the same problem. Did this fix work for you? If not how did you get it working?
    147,878Coins
    +10,880 / 54 / -2
    The fix is actually proper configuration. Please do not cross post an issue across multiple threads, it gets way too difficult for others to follow or offer advice.
