Some questions about my next sim
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by mariano68, Aug 1, 2016.
  1. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    I'm researching for my next sim (4dof/6dof) and I have to take a decision about how to power it.
    It is cheaper for me to get 1 or 2 100amp gel car batteries and a charger, than to get 4 or 6 server power supplies, as I will be using 750watts winch motors that can be powered on 12v or 24v.
    1-I have no experience using car batteries, is there something that I have to know about them? or I just can connect them to the motors directly?
    2-Still deciding if running 12v or 24v, @24v with 2 batteries in series and IBT-2 bridges or @12v with dual MM's. Any pros and cons?
    Thanks anyway!
  2. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    Do you not need to regulate the power supply. a car battery can kick out 14v which could ruin some equipment. I Know with scn's you have to have protection from over voltage
  3. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Thanks for your reply
    What kind of protection?
  4. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    not much help im affraid on the battery side but some of the power supply units are regulated voltage so you cant put too much power out. i wouldn't have a clue how to do it on batteries. it would probably be created with resistors some how. If it were me i would use power supplies to be on the safe side. the last thing i would want is something going bang. Also for piece of mind
  5. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    @crammy you're right, but it is just a question of money, I can't get cheap server psus here, and I can't legally import psu (weird legislation).
    About the voltage spikes, I think that if I use for example the IBT-2 drivers ( 6V-27V) would be no problems, anyway, if there is some kind of cheap regulator that would be great.
    Iirc @Pit use or used Bateries in his sim, I would have to ask him.
  6. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    No problem mate. I had the same here. The power supplies I wanted as was going to get were relatively cheap. I never purchased at the time and when I went back to buy them a few weeks later they were all of a sudden non UK compliant and illegal to sell to me so had to spend twice as much.
    I'm sure it can be done with the knowledge. Yours may not even need regulating. I just knows scn's do.
