Question Sourcing actuators and power electronics
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by pki, Mar 4, 2026 at 22:51.
  1. pki
    pki New Member
    Yesterday
    16Coins
    Hi there.
    I am trying to source actuators for my 6DOF build. I like not only racing but i want to try also flight sim. Both with VR.
    Now firstly i choose 300mm travel, 500mm/s, 1kW actuators with chineese controller. I see the prices are not easy for hobby projects, but i dont want to build the actuators by self, i could but i have enough other projects in progress :)
    As far as i understand correctly i need a thanos controller to connects that 6 servos to the software. Is it still top, or should i go any other way in 2026? Maybe that knaufinator controller is okay also, i am familiar with ESP32 and soldering.
    Do You have any recommendation on actuators, i would also accept 500mm stroke when the price is nice.
    I got a calculation for an actuator called QDA75-R300 from QIANGDELI and a controller P100S AC Servo from DVS. Seems this can be controlled my pulses or by RS485.
  2. Misanthrop
    Misanthrop Active Member
    898Coins
    First you should choose the Controller you want to use. The only Controller supported by Thanos is the AASD. Otherwise there is Motion4Sim who supports more and modern controller with Canbus, but even there are only few Controller who gets supported.
