SymProjects- Rev Burner or GI Pro( Anyone used?)
Discussion in 'SimTools compatible interfaces' started by caliliving714, Oct 5, 2011.
  1. caliliving714
    caliliving714 New Member
    4Coins
    Searching for a way to control my 5 rev meter. I came across this company.
    http://www.symprojects.com/
    With Rev Burner you will able to connect a REAL rev counter and speedometer to your PC, through the USB port. Any electronic gauge is compatible so all you have to do is to buy the one you prefer the best.
    The GI Pro board is a gear indicator display.
    looks like what I'm looking for. The Rev B is about $40 U.S. It also states that you need some oftware running with it as well.
    Anyone used it? Any good?
  2. abs
    consultant
    Montreal
    774Coins
    3DOF, SCN5
    it works fine . I have a rev counter , a GI max, spi-d. They all work in x-sim via a plugin.all work within x-sim (no program running in the back ground unlike the sli-pro)
    ask cristiano -contact him at symprojects.com he is very helpfull
    the only think that is not yet supported for x-sim is the pro-shift and the lcd that he provides.
    one thing, mechanical dials are not supported , only electronic dials. the majority of tacks are electronic. you can mod a tack and get a cheap speedometer . I used a face plate from a bmw and glued on top a cheap tachometer. It works which symprojects plugin for x-sim
    check:
    http://www.symprojects.com/x-sim/
  3. Jadran
    Jadran Member
    Racing game:LFS,Simbin (Race07,GTREvo,RaceOn)
    Osijek,Croatia
    3,207Coins
    Hi!
    I use 2 Rev Burnes (one for RPM and one for speed) and Pro Shift for dash(cluster) light.
    With old faceplate
    http://www.youtube.com/watch?v=oSeqG1dlTwg
    With new plasma faceplate
    http://www.youtube.com/watch?v=hgXU5lYM7p4
    Look here:
    http://www.symprojects.com/forum/index.php?topic=38.0
