The logykal setting
Discussion in 'SimTools compatible interfaces' started by siukui, Sep 2, 2014.
  1. siukui
    siukui New Member
    Hong Kong
    250Coins
    2DOF, SCN5
    hi all
    I m the user which using the Logykal e69 motion 2dof B4
    And I decide to change to use Simtools and I ve already buy the access for the Rfactor2 and Assetto Corsa...
    but i cant fixed the interface setting by SCN because i just hv 1 com-port output
    is it i should b set it up by SER? If yes, how can i do?
  2. yobuddy
    49,199Coins
    I'm sure we can get you up and running!
    SimTools uses 1 SCN per RS Adapter.
    With the ID's of the actuators both being zero (the default ID number)
    Do you have one SCN actuator working?
    yobuddy?
  3. siukui
    siukui New Member
    Hong Kong
    250Coins
    2DOF, SCN5
    Mind one is 2 SCN and just 1 rs output
    So I just can select 1port per 1axis
    And yes, there's just one actuator is working
  4. Silvano
    Silvano New Member
    348Coins
    2DOF, SCN6
    Same set as Suiki with 2 x SCN6 150 mm and 1 usb converter for both actuators, so I need be able to choose same port (com3) for both axes but when I want to assign axe2, there is only com1 to choose.
    the other question is what to choose, SER or SCN (I tryed both and no way to allow same port for both)
    thanks for any help :sos
    @Suiki I also have LOGYKAL but it lacks of plugins for PCars and AC (RF2 is working though)
    147,890Coins
    +10,880 / 54 / -2
