Question Transform a fixed rig into a mobile one
Discussion in 'DIY peripherals' started by jchuillier, Jan 21, 2025 at 15:37.
  1. jchuillier
    jchuillier New Member
    Tuesday
    34Coins
    SCN6
    Hello all,
    I just got 2 SNC6 and a LOGYKAL control box as a present and I'd like to upgrade my fixed simrig (alu 40*80), are there any drawings, tutorials, todo lists (and NOT todo lists) and so on ?
    Thanks for the help
    149,090Coins
    +10,928 / 54 / -2
  3. jchuillier
    Tuesday
    34Coins
    SCN6
    Thanks a lot for the reply but at the moment I'm still in hardware mode :)
    How do I attach the SCN to my rig ? Do I need to make a subframe ? Can the actuators directlmy push on the floor or is it better for them to have some "feet" ? And so on :)
  4. Misanthrop
    Misanthrop Member
    226Coins
    Depends on what you want. With only two actuators, you can only build a 2dof system like a seatmover without heave. So you should google first or read many Projects here, before we can help you for an direction.
    149,090Coins
    +10,928 / 54 / -2
    A shoulder mount design is most commonly used for a SCN powered rig, here are a few examples:
    https://www.xsimulator.net/community/threads/x4-actuator-scn6-motion-rig.12969/
    https://www.xsimulator.net/community/threads/3-dof-scn6-simulator-with-traction-loss.12577/
    https://www.xsimulator.net/community/threads/blecos-2dof-scn5-racing-simulator.2625/
    But there are many more to projects to search through for inspiration: https://duckduckgo.com/?q=site:xsimulator.net+SCN+2dof&ia=web
