Tried to delete this topic. But can't??
Discussion in 'Motor actuators and drivers' started by HAVOG, Jan 22, 2009.
  1. HAVOG
    HAVOG New Member
    High and Low voltage technician, production automa
    Denmark
    299Coins
    Yes.. As it says above..
    How?
  2. tronicgr
    tronicgr
    Re: I got new toys! Omron 200V DC 750W step motors and drivers..
    Can you provide us the manuals? On the site link you gave you need login to be able to download them... Or else give us the model you have to search it elsewhere.
    Regards, Thanos
  3. HAVOG
    HAVOG New Member
    Denmark
    299Coins
    Hi
    Hmm... on my computers all three links works like a charm. And i don't have to login anywhere.
    The whole ting is a kit, this is the 750W, in the series called OMRON SMART STEP and should be somewhat easy to setup through a PLC. It comes with both motor, gear and driver. But i really wan't to control it directly through the AVR/PWM board that you designed, Thanos. So if i can get 0->10V/-0 -> -10V or 4-20 mA out of the AVR I think it will work. Another solution is to connect the PC or AVR->analog input on the plc->driver->motors.
    The motors are OMRON R7M A75030 S1-D = (750w 3000rpm)
    The motordrivers are OMRON R7D-AP08H
    Here's the google search on smartstep 750
    <a class=postlink href=http://www.google.dk/search?hl=da&newwindow=1&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=smartstep+750w&spell=1 target=_blank>http://www.google.dk/search?hl=da&newwi ... 0w&spell=1</a> target=_blank
    Vogt
  4. tronicgr
    tronicgr
    I located a proper datasheet for your servo controller and from what I've read its not so easy to interface it to my AMC controller...
    http://www.inverters.ru/dynamic/managers/manage_26/files/SmartStep_DataSheet_v0.99.pdf
    Your servo controller features the following options for control:
    -RS-422 network protocol
    -RS-232 commands (haven't found the command set though)
    -Step pulses to each direction (if to be used in CNC applications)
    No analog input???? :eek:
    Regards, Thanos
