Question Tuning center
Discussion in 'SimTools DIY Version' started by Mxcobra, Apr 22, 2017.
  1. Mxcobra
    Mxcobra Member
    229Coins
    When I turn on the tuning center it seems to work fine. But when i launch a game (No Limits2) it keeps defaulting the profile back to assetto corsa. And then its locked and i cant change in the drop down. Any ideas ?
    147,878Coins
    +10,880 / 54 / -2
  3. yobuddy
    49,199Coins
    Hi @Mxcobra,
    This error is cause by NL2 not shutting down correctly like Noorbeast mentioned.
    But it also causes the next game played to have the wrong game entered in the profile.
    To fix this problem, navigate to:
    C:\Users\(your users folder)\AppData\Local\SimTools\GameManager\GameProfiles
    (appdata is a hidden folder, so your pc needs to have the setting to show hidden folder and files)
    Now simply delete everthing in the GameProfiles folder so it is empty.
    Including the "LastUsed" and the "Profile" directory's.
    Now restart Game Manger and you should be good to go!
    (yes, you will need to re-setup any profiles you had in game manger, but its not to hard)
    I am looking at way to avoid this problem in the next release.
    So that any game with a shutdown problem in the future, won't cause SimTools to record the wrong game being played.
    Hope this helps buddy,
