Useful UDP C++ code that needs improving
Discussion in 'Miscellaneous' started by traveltrousers, May 15, 2017.
  1. traveltrousers
    traveltrousers Active Member
    Timbuktu, Tombouctou, Mali
    890Coins
    https://forum.unity3d.com/threads/simple-udp-implementation-send-read-via-mono-c.15900/
    has a couple of nice scripts that usually work, or at least I can use the receive script to grab UDP data from simtools. It doesn't handle errors very well, but I thought it would be useful for someone on here... especially if they have some suggestions for making it 100% reliable! :)
  2. traveltrousers
    890Coins
    update:
    The UDP section in this tutorial works perfectly to receive simtools UDP data and handles disconnects and reconnects perfectly! You just need to parse what you're getting...
