Usefull
Discussion in 'Suggestions for improvements - Oudated' started by Renoboss, Jan 8, 2007.
  1. Renoboss
    Renoboss Member SimAxe Beta Tester Gold Contributor
    Work, Motion Simulator and High Tech Fishing
    Netherlands (Frisian)
    297Coins
    2DOF, SCN5
    Sirnoname,
    Is one of the products of this company usefull?
    http://www.codemercs.de/D_index.html
  2. Renoboss
    297Coins
    2DOF, SCN5
    Can perhaps the JoyWarrior24 A8-8 be used as inputdevice and IO-Warrior24 used as output controller?
    Does calibrating the RnR work this way?
    Will reaction-time be an issue?
    Perhaps a setup of IO-Warrior56 NEW can be used with a nice LCD-setup?
    Can you also check the following units in .pdf
    http://www.andare-ing.com/uploads/Iocards_catalogue.pdf
    Specific the USB-relayscard!! ( http://www.opencockpits.com/modules.php ... age&pid=58 )
    (more on http://www.opencockpits.com/modules.php ... age&pid=29)
    Prices are interesting also!
  3. Renoboss
    297Coins
    2DOF, SCN5
    Referring to the warrior-units or the Opencockpits?
    (I'm just trying to find payable ready to use USB-boards for future Motionbuilders and offcourse easy to implement-boards for the Profiler.exe , because as you see I can make hardware setups!! but reproduce the RnR-usbboard you designed is not my skill !!)
