USO datapacket ASCII commands
Discussion in 'Force-Profiler Simulator Control' started by Imaginex, Sep 10, 2009.
  1. Imaginex
    Imaginex New Member
    London, Canada
    Hi, I'm attempting to configure a 12 bit DAC module for 0-10 Volt output but am running into difficulties with the USO parser function. The module requires serial data as follows: AV (module A, Voltage), channel (A,B,C etc), axis value(0-1000), return;
    no handshake needed
    I got 1 axis working with: AVA~a01~~13~ but can't seem to get the correct string for all 3 axes;
    i.e. AVB~a02~~13~ and AVC~a03~~13~
    any ideas on incorporating the 3 axes into a single string with return?
    fyi - the module outputs 4 channels of 12 bit analog (0.01 volt resolutions), any voltage between -10 and +10 VDC,
    20ms response, and a lot of other neat features(ramps, pause, calibration) less than $100 USD;
    if anyone is interested let me know and I'll pass along the vendor info
    to get a 0-10 Volt value (0-1000) I used 16 bit resolution, decimal output with the formula, /65536*1000;
    the module then scales this to 12 bit output
    if anyone has any ideas on the string/parser function it would be much appreciated
    thanks!!
  2. Imaginex
    Imaginex New Member
    London, Canada
    Hi - it's one 4 channel module on a single comport, RS-232, read mode only - no return
    thanks for the serial port monitor suggestion - with this I could see that the USO datapackets were hitting the DAC module too fast and it couldn't read & calculate the four channels outputs fast enough - it just bottle-necked with error.
    ideally, this module would like to see each channels' values in a separate string e.g. AVA500~13~ (I'm assuming with 1-2 ms delay in between)
    since the USO can only output 1 datapacket per cycle, the initial attempt that froze the DAC module was:
    AVA~a01~~13~AVB~a02~~13~AVC~a03~~13~
    the revised datapacket that works is:
    AVA~a01~~13~~13~~13~AVB~a02~~13~~13~~13~AVC~a03~~13~~13~~13~
    by inserting 2 additional carriage returns after each channels values it creates enough of a delay within the datapacket to give the module time to receive & compute each channels' value. (not ideal but it works well)
    the datapackets are being sent with only a 10-20ms pause between them;
    btw - this 12 bit analog output ($99 USD) combined with a 12 bit joystick interface ($50 USD) produces very high resolution input/output and I'm very pleased with the sim's performance at this stage!
    if anyone is interested in any of the above just say and I'll provide more info
    thanks again
