USO not recognizing COM port (Pololu servo controller)
Discussion in 'Force-Profiler Simulator Control' started by Frakk, Aug 12, 2010.
  1. Frakk
    Frakk Active Member
    328Coins
    I have been trying to make a Pololu Micro Maestro (http://www.pololu.com/catalog/product/1350) working with the USO, but I cannot get it to recognize the virtual COM port.
    The drivers are all installed and there are no problems apparent in the device manager. I have tested it with the provided application and I can also make connection to it with Hyperterminal.
    Has anyone tried this before? Any ideas for possible solutions?
  2. dhweizel
    dhweizel New Member
    Buenos Aires, Argentina
    339Coins
    Do you use the form \\.\COM1 (with the appropiate number) to add the COM port to USO?
  3. dhweizel
    dhweizel New Member
    339Coins
    sorry for the obvious frakk, I did not realize you were not a rookie and I made that mistake at the beginning :lol:
  4. Frakk
    Frakk Active Member
    328Coins
    Well, it seems like I am... :blush:
    I have used different types of USB-Serial modules and they have always showed up in the drop-down list, never needed to add like this \\.\COM?.
    The connection seems to be working! Now I'll play with the commands and all that.
    Thanks!
  5. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    437Coins
    It may be that COM ports higher than 8 or 9 do not show automatically in the dropdown box. You can easily test this by changing the COM port number in in the USB driver itself and restarting X-Sim.
  6. Frakk
    Frakk Active Member
    328Coins
    I have successfully used COM9 with an FTDI adapter that was automatically recognized in the drop-down list, so this will be something else.
    BTW currently the controller is on COM7.
    I'm almost sure it is the Pololu drivers, they are non ISA comports. FTDI drivers seem to be very robust and that is the reason why the USO recognizes those non ISA comports just like any other, even above COM4.
