Question V3 Motion Axis and Dash on same serial interface?
Discussion in 'SimTools Pro & Entertainment Version' started by DigitalDazz, May 27, 2024.
  1. DigitalDazz
    DigitalDazz New Member
    - 6Coins
    I would like to ask if anyone has knowledge on using the motion axis to work with dash connected to one Arduino.
    I have a seatbelt motion system working with servos on the motion interface on com4 and I am trying to get the dash <po1>~ data sent to the same arduino on Com4.
    The gear change response works fine on arduino, but only if the motion interface is disabled.
    I have tried adding "G<Po1>~" to the motion interface output but this does not work, nor does setting up com4 on the dash setup.
    Does anyone know of a way to combine motion axis and dash in the same serial connection?
    The following is my axis interface output R<Axis1a>~L<Axis2a>~
    146,170Coins
    +10,810 / 52 / -2
    You can't have 2 different control systems trying to use the same com port, is that what you are trying to do, and what exactly is the dash you are taking about?
  3. DigitalDazz
    - 6Coins
    Yes, I am trying to output Dash <po1>(Current gear) with the motion axis data. I guess this can be done in the profile. I am trying with two arduinos linked with a software serial connection on RxTx(pins 10,11).
    146,170Coins
    +10,810 / 52 / -2
  5. DigitalDazz
    - 6Coins
    Hi, I am using V3.0, which has built in dash outputs.
    I have gave up using linked Arduinos, it is possible but seems a bit fiddly to get them to communicate reliably.
    To be clearer, I want to replicate the effect a gear change has on the seat belt servos I am controlling, by temporarily reducing the angle of the current positions based on gear changes.
    The seat belt servo are controlled by the axis motion outputs, I just wanted to expand on the current feedback they give.
    I had hoped there would be a way to output the dash gear position on the same serial connection.
    I suppose this might be possible using the game plugin, if I had the source code.
    I am a new user so still finding my way around what is possible with it.
    Not looked at previous version, yet.
  6. yobuddy
    48,411Coins
    @DigitalDazz,
    Hi Buddy,
    What plugin are you playing with?
    I can add the data to a test plugin for you.
    My guess is no matter what gear the vehicle goes into the output should be -1 for a bit. (except neutral, I think it should be 0 - no output)
  7. DigitalDazz
    - 6Coins
    Hi there, I am using the AMS2 plug in.
