Valve response time vs max switching frequenzy
Discussion in 'Pneumatic equipment - outdated' started by SimHawk, Oct 5, 2007.
  1. SimHawk
    SimHawk Member
    Engineer
    Norway
    Hi, I am reading valve specification sheets and I have one question.
    Some valve datasheets refer to response time others to max working frequency. Are they directly connected to each other like:
    10Hz = 100ms/2 = 50ms response time? Is it between to positions in a 3 position valve? Any position?
    I am trying to find out which 5/3 valve I can use.
  2. egoexpress
    5/3 Valves do open/close the exhaust automatically. That means practically, that you have virtually 4 valves (2x air-intake;2x air-outtake) with a single 5/3 valve.
    Switching freqency depends on the travel lenght the internal slider has to move from one to another position.
    Watch out for 5/3 middle closed with 1/8 conection response time < 25ms.
    Ask the manufactuer for the response time. If he does not want to tell you the detailed specs, then they are probably bad^^
  3. SimHawk
    SimHawk Member
    Engineer
    Norway
    Is it correct that a response time of 25 ms would be 20Hz working freq?
