Violently shaking Dofreality P3
Discussion in 'Commercial Simulators and Peripherie' started by Muovipotilas, Apr 8, 2018.
  1. Muovipotilas
    Muovipotilas New Member
    Finland
    240Coins
    Hi, I have a problem with my dofreality P3 when running Project Cars (1), when I start the game, the chair starts to violently shake, and I have to turn off the game to make it stop. Simtools has been configured and registered properly, as the chair works just fine with dirt rally, kart racing simulator and NoLimits Roller Coaster Simulation 2 without any problems at all. I am using the plugin provided by dofreality, which I got with the chair, so it shouldn't be a problem with the plugin. Anyone have any suggestions on how to fix this problem? Thank you in advance!
    147,926Coins
    +10,882 / 54 / -2
  3. Muovipotilas
    Finland
    240Coins
    Alright thank you, will do that, will come back and tell if that fixed my problem!
  4. Muovipotilas
    Finland
    240Coins
    didn't fix anything, still violently shaking even when putting everything to the minimum values, cant capture the min max values either because of the shaking, and us being afraid that the P3 breaks because of this
    147,926Coins
    +10,882 / 54 / -2
    You can manually set high Tuning Center values, say 50, then tune them down from there after capturing the values.
    Out of curiosity what are the language settings for your PC?
  6. Muovipotilas
    Finland
    240Coins
    Here are the pictures. ah didn't notice how to do that but will try to manually tune them now as well! The pc is in English
    147,926Coins
    +10,882 / 54 / -2
  8. Muovipotilas
    Finland
    240Coins
    Yep project cars is configured like that! will try now to manually set the max values to 50 in tuning center.
    147,926Coins
    +10,882 / 54 / -2
  10. Muovipotilas
    Finland
    240Coins
    no we havent, will try that now! will inform if it helps!
  11. Muovipotilas
    Finland
    240Coins
    ok now we tried the udp, now when we turn the steering wheel to the right for example, it moves the tracktion loss to the left, even when the car is not moving in the game. The violent shaking stopped with udp though
  12. noorbeast
    147,926Coins
    +10,882 / 54 / -2
    OK, the Dir boxes in the Axis Allocation being checked orange or not determine which way the axis moves, so set it the opposite of what you have now for traction loss. But if it is moving when the car is not then the axis allocation and tuning center value also need refining, particularly the latter as it was set to 0 in your previous picture, which could also be the issue with the original plugin, start at 5 and see how it reacts.
  13. Radioproffi
    Lviv
    1,569Coins
    Please change settings like on screen below. You can find this settings in GameEngine - > Tools -> Tuning Center.
