Question What is the easiest way to move to a new PC
Discussion in 'SimTools DIY Version' started by Alexander Asner, Mar 7, 2019.
  1. Alexander Asner
    Alexander Asner New Member
    271Coins
    3DOF, SCN5, SCN6
    I am planning to buy a new PC shortly. In order to move my motion setup to the new machine, what is the easiest way? What can I copy over to the new installation, and what parts of the setup would I have to repeat manually.
    Any help is much appreciated.
    -Alex
    147,878Coins
    +10,880 / 54 / -2
  3. Alexander Asner
    271Coins
    3DOF, SCN5, SCN6
    Thank you. I suppose I would have to set up the assignments from scratch though, or is there some kind of ID for the actuators that is stored in the settings?
    147,878Coins
    +10,880 / 54 / -2
    The backup will store all current Interface, Axis Assignment and Game Manager profiles.
  5. Alexander Asner
    271Coins
    3DOF, SCN5, SCN6
    Ok. That sounds fantastic. I'll keep my fingers crossed.
    147,878Coins
    +10,880 / 54 / -2
    Depending on your hardware you may need to check the Interface Settings, as a different port could be allocated. The rest should be fine.
    You also have a limited number of SimTools registrations, so just go ahead and re-register your SimTools install when you do it.
