What motors should I get for my simrig?
Discussion in 'Ready, set, go - Start your engines' started by Stephenuhhh, Jun 24, 2024.
  1. Stephenuhhh
    Stephenuhhh New Member
    - 14Coins
    I am planning to build a 2DOF sim, but I have no idea what motors I need. I have done torque calculations, and apparently I need at least 20NM of torque. I have no idea if this is actually true, and trying to find a motor in the price range of 50-80€ each is insanely hard. The only ones I can find are from China with crazy shipping fees. Does the torque actually matter as much as I think it does, and does anyone have motors that they have used in a similar design? (preferably EU or UK suppliers)
    My design has two motors with arms at the front of the rig, between the pedals and the ball in socket joint, which will be located directly below the seat. I would like a vertical travel distance of around 10-14cm, so a radius of 5-7cm on the arm. (sorry if none of this matters, I really want to double check everything before I buy)
    152,627Coins
    +11,087 / 56 / -2
  3. Maloi
    Maloi New Member
    Mechatronic Engineer, Teaching Assistant
    Indonesia
    27Coins
    i use two 12V DC motors (originally a truck wiper motors). Still working properly for someone with 90kgs
  4. ockert engelbrecht
    ockert engelbrecht New Member Gold Contributor
    - 245Coins
    2DOF, 3DOF, DC motor, AC motor, Joyrider
    my firs rig i use 24 v garage door motor dc blue digital sectional door motorand my second one i use 24v gate motor centurion d5 evo smart motor
    had to fit it to a 1-60 gear boxs
  5. Nash_NZ
    Nash_NZ New Member
    52Coins
    Seen a few rigs on here using the MY1016Z 24v 75rpm... I've also brought these for my build, hopefully the right choice.
  6. Stahlwolle
    Stahlwolle Member
    268Coins
    24v, 250W 75rpm wheelchair Motors.Then you know that it works and it is a cheap option!
