what potentiometer to use
Discussion in 'Motor actuators and drivers' started by steveh2112, Oct 4, 2016.
  1. steveh2112
    steveh2112 Member
    semi retired
    Phuket, Thailand
    1,147Coins
    i'm building a 2DOF rig based on this post
    https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    for the position feedback i guess i need something like a 10k linear pot right?
    is a cheap 20% accuracy chinese pot ok or should i be spending $20-30 or more on a precision audiophile grade pot?
    thx steve
    PS, i just got this
    http://www.ebay.com/itm/141814699999
    US brand
    Standard Resistance Tolerance ±10% Minimum Practical Resistance Tolerance ±5% Independent Linearity2 ±1% Minimum Practical Independent Linearity ±0.5%
    hope that's good enough
    148,682Coins
    +10,915 / 54 / -2
  3. steveh2112
    steveh2112 Member
    semi retired
    Phuket, Thailand
    1,147Coins
    thanks, i just ordered a flexible coupling too.
    i guess i'll go the the pot for now, maybe upgrade to hall sensor later, i'm not worried about over rotating, tilt range will be limited mechanically to +/- 20degrees or so
    BTW, thanks again noorbeast for all your help.
    i noticed the hall sensor you use has 'Independent Linearity ±0.5%'
    the pot i chose is from the same manufacturer (BI technologies) and looks like it has the same Linearity
